Vraag 12622
Venster
Vraag 12622
Bericht door Venster »
Welke borden slaan op de Maximaal Toegelaten Massa van een voertuig?
A. Bord 1 en 3.
B. Bord 2 en 4.
C. Geen van deze borden.
Alle 4 de borden hebben hetzelfde onderbord, waarom slaat dit dan soms om MTM en soms op MBM? Wat is de beredenering hierin. Ik zie de logica simpelweg niet..
Re: Vraag 12622
Heb je de theorie hierover doorgenomen :?:
Re: Vraag 12622
https://www.gratisrijbewijsonline.be/th ... mtm-en-mbt
Toch belangrijk dat je dat goed kent.
Hopeful_to_pass
Re: Vraag 12622
Bericht door Hopeful_to_pass »
To be honest I also do not understand in what cases the signs relate to the MAW and when to the MGW . I've read the theory and tried to find further explanation online but no luck. Hopin it doesn't;t come up on exam
Re: Vraag 12622
This is very important for the exam.
You can find the theory on our English site: https://www.drivinglicence-belgium.be
Hoping_to_pass
Re: Vraag 12622
Bericht door Hoping_to_pass »
I have the book + practice book in English . The general difference I , of course , understand. What is confusing is which one applies to what sign . Exactly like in this question :(
Re: Vraag 12622
That's explained in your book. And that you have to learn.
Hopeful_to_pass
Re: Vraag 12622
In the book it is explained the difference between MAW and MGW, but NOT which signs they apply to and why. I also have to add the English book is extremely poorly written with typos, occasionally appearing sentences in dutch, grammatically incorrect and unclear sentences etc
Re: Vraag 12622
So you are not talking about our book, because in chapter 9 everything clearly explained with pictures.
.https://www.gratisrijbewijsonline.be/th ... mtm-en-mbt
This is our Dut h site. Maybe you can use automatic translate.
Re: Vraag 12622
Hoping_to_pass schreef: 27 jul 2021, 19:46 I have the book + practice book in English . The general difference I , of course , understand. What is confusing is which one applies to what sign . Exactly like in this question :(
Signs regarding
P for Parking
I for Inhalen / overtaking as in "I want to overtake"
C for Cruise control
S for Speed
Refer to MAW (max allowed weight)
Re: Vraag 12622
Thanks so much Inazuma- clear to me now! Looks like the English translation is not so good compared to the Dutch one :)
qu1nt3n
Re: Vraag 12622
Bericht door qu1nt3n »
Toch nog een vraag hierover. Ik begrijp het geheugensteuntje "PICS" en de gedachtengang hierachter. Maar in het antwoord op de oefenvraag wordt gezegd dat afbeelding 3 slaat op de Massa in Beladen Toestand:
Terwijl in de uitleg in de theorie bij dit bord het omgekeerde staat vermeld:
Het geheugensteuntje volgend is het antwoord op de oefenvraag juist, maar dat betekent ook dat de uitleg bij dit verbodsbord op de theoriepagina fout is.
Re: Vraag 12622
Het onderbord bij Bord 3 / aka C23 Afbeelding gaat wegens een aanpassing aan de wegcode sinds kort ook over de MTM
Vraag en juiste antwoord zal dus aangepast moeten worden
Het geheugensteuntje kan blijven :
PICS: MTM
C - voordien Cruise Control, maar die borden zijn geschrapt uit de wegcode- kan nu voor Camion staan :wink:
Re: Vraag 12622
Dank voor het melden.
Deze vraag was mij ontsnapt. Ze is aangepast.
qu1nt3n
Re: Vraag 12622
Dank, beiden!
